12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009 Add Levels to Dwg
167 Posts No Rating |
Searched the forum for this one and read Revit help,
Imported dwg into a drafting view. Is there a way to add a revit level for graphic standards to the dwg. I believe I have tried almost everything.
Using Revit Architecture 2012 |
Levels are a 3D element.
You did know that you can create a 3D view and place your darfting elements in that view?
Thank you...of course I knew that....no I did not...
I have looked in Revit help and on this forum but cannot find where it details how to create a 3D drafting view.
I didn't suggest a 3D drafting view, I suggested a 3D view.
In your case, you wanted to see a level. I assume this is some sort of detail that somehow cuts a level. So do that! Create an appropriate section or detail view, place your imported 2D elements and turn off any 3D elements you don't want.
cheers
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg) |
Mon, Jul 13, 2009 at 3:55:27 PM
Revit 2009 Importing Structural Dwg |
Thu, Aug 25, 2011 at 2:31:17 PM
import dwg to revit but cant underlay |
Sun, Apr 26, 2009 at 5:24:18 AM
Revit 2009.1 Bind Revit Link Does any one know if 2009 has improved this? |
Tue, Oct 14, 2008 at 3:36:56 PM
Rev 2009 Importing Structural Dwgs into Arch dwg |
Mon, Jul 25, 2011 at 7:39:15 AM
