23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Any way to set Wall Join Display to not clean any walls?
Mon, Sep 19, 2011 at 12:45:39 PM | Any way to set Wall Join Display to not clean any walls?
structuresguy
When doing a tilt-up building, it would be very nice if the default wall join setting was "do not clean any joins".  But I only get two options, "Clean all joins" and "clean same type joins".   Is there a trick or workaround to get it to not clean any joins?
Thanks.
Mon, Sep 19, 2011 at 1:19:19 PM | Any way to set Wall Join Display to not clean any walls?
Most people do not use wall segments for tilt up walls.  Since I don't schedule individual panels, I use a continuous wall with vertical wall sweeps (voids) at the panel joints.  When you do need to schedule the panels, some users use curtain wall with the panels being a wall panel and the muillions the joint.
Wall Join Display
Thu, Oct 14, 2010 at 12:52:50 PM
Clean wall join
Sat, Apr 20, 2013 at 3:30:48 AM
11
Wall Join clean up
Wed, Mar 6, 2013 at 12:14:30 PM
90degree wall join
Sun, Aug 20, 2006 at 9:08:54 PM
wall joins at stacked wall not clean
Mon, Nov 15, 2010 at 11:57:34 AM
Page generation time: 2.1990
