Forums >> Revit Building >> Technical Support >> Delete Section Type
Mon, Sep 19, 2011 at 5:21:22 AM | Delete Section Type
JohanEkstrom
I'm trying to delete a section type by purging the file, but it wont show in Purge. I have tried to confirm that the type isn't used in the project by selecting all instances in entire project and changing them to the other type but it isn't enough. Am I missing something?
Wed, Dec 14, 2011 at 4:42:29 AM | Delete Section Type
bearand
Hey
You can purge the section type, just under "other styles" in purge unused.
Wed, Dec 14, 2011 at 7:04:23 AM | Delete Section Type
You can not delete the system created section type because Revit wants at least one available.  That one has probably been renamed or is not a name you like.  Rename / fix it so you can keep it.
Assigning a scope box to a section leads forces me to the delete the section.
Mon, Jan 11, 2016 at 10:10:53 PM
Building Section Reference Label
Tue, Sep 11, 2007 at 2:44:22 PM
Create Wall Section Type
Thu, Jun 30, 2011 at 3:58:23 PM
Cannot delete type instance of titleblock
Fri, Mar 24, 2017 at 12:02:31 PM
Delete a dimension type
Mon, Oct 17, 2005 at 3:06:39 AM
Page generation time: 2.7410
