Forums >> Revit Building >> Technical Support >> What does the "lock" column mean when we set up a family
Fri, Sep 16, 2011 at 10:23:14 AM | What does the "lock" column mean when we set up a family
xixiha
I have been haunted by this for a while. When I set up a family, for each parameter, the last column is called Lock, which comes with a box to check. I used to think this can lock that parameter, but turned out not.
Anyone knows what this means? Thanks.
Fri, Sep 16, 2011 at 10:45:11 AM | What does the "lock" column mean when we set up a family
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
This lock column means that other parameters can't change the value of that parameter. For example if you had two paramaters defining a horizontal length and you changed one, the other would change unless it was locked. This does NOT mean that you can't change the value for locked parameters it just means it maintains the value when other parameters are changed. A simple dimension that is locked, however, is called a constraint and it can't be changed.
Sat, Sep 17, 2011 at 9:20:14 AM | What does the "lock" column mean when we set up a family
coreed
coreed Avatar
4 Stars: 16 Votes
Here, this should exorcise your haunting:
http://revitoped.blogspot.com/2011/09/dept-of-subtle-family-editor-parameter.html
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Specification column "Elevation at Bottom"
Wed, Jan 28, 2009 at 7:43:12 AM
14
model: column-"properties" dims not scaling to whats shown on drawing
Fri, Dec 12, 2008 at 3:10:11 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
New column based on concrete column family
Fri, Aug 8, 2008 at 3:37:56 AM
plaster on column? "really in trouble"..
Tue, Dec 18, 2007 at 9:07:39 AM
Page generation time: 1.1548
