Forums >> Revit Building >> Technical Support >> Revit 2012 Elevation Display Issue
Thu, Sep 15, 2011 at 4:44:59 PM | Revit 2012 Elevation Display Issue
Bomhour
Hi all,
Ive been using revit since 2008 and have never had this issue before.  My building elevations are displaying transparent dispite being set to Hidden.  Is anyone else having this issue?  Know a fix?  I have checked all the things I can think of; display setting, depth clip, transparency of walls...etc.
Please help.
Thu, Sep 15, 2011 at 6:54:10 PM | Revit 2012 Elevation Display Issue
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
do you have any dwgs linked in?
I have had this problem from linking consultant backgrounds into my building. I ended up having to explode the dwgs and make sure they were centered(ish) on 0,0
Edited on: Thu, Sep 15, 2011 at 7:00:32 PM
Thu, Sep 15, 2011 at 7:25:42 PM | Revit 2012 Elevation Display Issue
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I've seen this issue.  It was related to a corrupt view (usually caused by having lots of items in the Review Warnings).  For me I just recreated the view and copied across the annotation and the new view was fine.  So then just deleted the old corrupt view...
Regards,
Chris.
Thu, Sep 15, 2011 at 10:50:59 PM | Revit 2012 Elevation Display Issue
Bomhour
Ok, I deleted the view and recreated it.  That worked for 3 of the 4 elevations.  the 4th view was only fixed after I deleted an inserted DWG.  You were both very helpful.  Thanks.
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
2012 Design Review Incorrect views
Fri, May 20, 2011 at 3:52:43 PM
Elevation consistancy issue in 2012
Tue, Dec 20, 2011 at 12:45:33 PM
revit 2012 - display option background disappeared and turned black
Mon, Jun 25, 2012 at 4:48:13 PM
Abolute Elevation and Topo Points - Revit Architecture 2009
Wed, Feb 10, 2010 at 12:51:32 PM
Page generation time: 1.5708
