Forums >> Revit Building >> Technical Support >> disable work sharing
Thu, Sep 15, 2011 at 2:24:44 PM | disable work sharing
hhwse
I heard that in Revit 2012 you can stop work sharing if you no longer need worksets.  How do you do that?
Thu, Sep 15, 2011 at 3:18:02 PM | disable work sharing
Open the file detached and the option will be there.
Thu, Sep 15, 2011 at 4:18:39 PM | disable work sharing
hhwse
I have opened a file but cannot find a command to remove the worksets.  Can you elaborate?
Thu, Sep 15, 2011 at 7:29:45 PM | disable work sharing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
  1. Start Revit,
  2. Use the Open Project command,
  3. Navigate to your file,
  4. Highlight it,
  5. Select the "Detach from Central" Worksharing Option,
  6. Select Open,
  7. Choose "Detach and discard worksets"
  8. Save File (Worksets now gone)
Regards,
Chris.
Thu, Aug 13, 2015 at 12:17:26 PM | disable work sharing
anacuper
Thank you Mr Spot! It solved my problem!
Work Sharing with School Projects
Mon, Jan 16, 2012 at 8:48:37 PM
Violation Sharing
Thu, May 24, 2012 at 8:33:18 AM
Best Practice to Sharing your Revit files with other disciplines or contractors
Mon, Aug 10, 2009 at 2:50:49 PM
Sharing Models
Tue, Jul 16, 2013 at 12:45:36 PM
File Sharing/Production
Fri, Oct 24, 2008 at 6:07:13 PM
Page generation time: 4.1408
