Forums >> General Discussion >> Revit Project Management >> room name in relation with plan regions
Thu, Sep 15, 2011 at 11:32:10 AM | room name in relation with plan regions
michB
Now my plan regions are fine but the room names are not-
Thu, Sep 15, 2011 at 12:36:24 PM | room name in relation with plan regions
Where is your room? I bet it starts at a higher level then your region.
Be careful with split-levels.  There should be a Revit level for each split and the rooms should be hosted on the correct level.
Fri, Sep 16, 2011 at 9:21:04 AM | room name in relation with plan regions
michB
Things are certainly getting ocmplicated....
The whole split level thing.  Now the issue is showing a room name schedule that only includes the level I want to show as sopposed to the whole building.  Up until now I have only converted single level schools into Revit.
Fri, Sep 16, 2011 at 9:29:48 AM | room name in relation with plan regions
michB
NEVERMIND-FOUND THE SCHEDULE FILTERS.
THANKS LOADS THOUGH...TRUTHFULLY IT'S NICE KNOWING THERE IS HELP WHEN NEEDED.
NOTHING MORE FRUSTRATING HTEN NOT GETTING ANYWHERE ON A PLAN.
Plan Regions
Fri, Jun 17, 2016 at 12:50:11 PM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Room Tag not visible using Plan Region? RAC 2009
Wed, Aug 19, 2009 at 12:26:44 AM
Room Tag is lost visibility is on
Tue, Nov 20, 2012 at 7:04:09 AM
Crop Regions, Keynotes & Room Tags
Sun, Dec 31, 2006 at 7:12:23 PM
Page generation time: 3.1593
