Forums >> General Discussion >> Revit Project Management >> revit Schedule Changing Columns to Rows
Thu, Sep 15, 2011 at 9:44:31 AM | revit Schedule Changing Columns to Rows
klhelms
Has anyone ever changed the schedules in Revit so that the Catagories are filled out in the Rows instead of the columns? I have a client that I am working on a revit implimentation with and i am converting there standards from CAD and they like to see there schedules read with the catagories vertically in the rows and the information filled out horizontally in the columns.
Thu, Sep 15, 2011 at 10:30:55 AM | revit Schedule Changing Columns to Rows
Sorry, you can't do this in Revit.
Fri, Feb 17, 2012 at 10:36:47 AM | revit Schedule Changing Columns to Rows
romanosyr
Sorta depends, if you are doing a drawing index and wanted to change say....the sorting order.  You could select all the sheets you wanted to change and then simply change that parameter under the properties, and your schedule will update.
Fri, Feb 17, 2012 at 10:55:06 AM | revit Schedule Changing Columns to Rows
rod23
5 Stars: 4 Votes
"It is not the strongest of the species that survives, nor the most intelligent, but the one most responsive to change" - Charles Darwin.  Forget your CAD standards and go with the flow of revit, you won't regret it.
http://www.turbosquid.com/Search/Artists/Revitaoist
Rows disappear from schedule after saving
Tue, Sep 2, 2014 at 2:30:41 PM
Horizontal schedules
Fri, Jan 16, 2009 at 8:26:00 AM
How do you "unsplit" a schedule?
Tue, Jul 3, 2007 at 2:37:22 PM
Revision Schedule Row Height
Tue, Aug 24, 2010 at 12:42:53 PM
Room Schedule-HELP Please!
Wed, Jul 16, 2014 at 2:48:32 AM
Page generation time: 4.0736
