21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Linetypes and Phases
When we change phases the linetypes all display as black solid lines. They still register as hidden, demolished, etc... but they display solid. Any ideas?
Post edited on 2005-11-30 20:09:37
Attached is a quick help guide for you, if you still have questions let me know and I'll walk you through it.
Sorry I wasn't clear enough. Yeah I know about graphic overrides. This is different. Details lines are the specific lines that are changing to solid black lines when you change the phase of the view. I can't figure why details lines would change. For instance the green LINES turn black, DEMOLITION lines turn from dashed to solid, etc.
Post edited on 2005-12-01 12:04:25
Are you sure you've drawn detail lines and not model lines?
Detail lines should not be effected by the phase setting. Model lines will be...
I'm not the one working on this file so I assumed they were detail lines. You're right they are actually model lines. So now maybe someone can explain to me why model lines change with respect to the phase. I guess the Revit developers wanted model lines to act similar to other Revit families with respect to phase filters.
Complex Linetypes in Revit? |
Mon, Jul 2, 2012 at 1:51:38 PM
DWG Revit export replacing linetypes with erronous linetypes |
Tue, Mar 17, 2015 at 10:07:42 AM
Getting CAD Linetypes into REVIT |
Thu, Jul 24, 2008 at 7:11:10 PM
Custom Linetypes |
Wed, Nov 7, 2007 at 5:53:17 PM
Capabilities to isolate phases |
Tue, Nov 28, 2006 at 5:43:02 AM
