13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> Cut a wall along a other wall
9 Posts No Rating |
Hello out there
I have a little problem with some walls and I hope some of you guys can help me out here :-)
I want to cut my “Basic Wall 500 mm” by the red line so the model follows the other wall. But I can´t. I have try different things like: “CUT PROFILE” (But I cannot even appoint the curved wall. I have also tried to make a “REF PLANE” along the red line and tried to cut the wall against it. Please help me :-)
-Carsten
If these are two walls, they should just join - or are they something else?
Otherwise, youcan add an in-place void to cut the curved wall.
9 Posts No Rating |
It is to foundation walls, one of them are in to the basement. I can use the “JOIN GEOMETRY” tool and make the tow wall join together but then I have a small piece of foundation in the basement and it will not be the right way to build it in the real life :-)
I have tried to use the in-place void but every time I got this message *(see the picture) did I do something wrong ?
Before you finish the void family, you have to tell it what to cut. BTW, Don't join these tow walls and cut them because the void will then cut both.
9 Posts No Rating |
It worked! I used the in-place void and cut it into the wall. WWHub you are the man :-) Thanks
9 Posts No Rating |
Okay now I have another proplem. Can I get back to my void and edit the site of if? If the wall that the curved wall is cut up by, later in the project change size to thicker or thinner how do I change the size of the void then?
The picture shows the void family (Structural Foundations1) but I can´t do anything with it :-(
1 Posts No Rating |
I've already install my new 2012 revit version....my problem was when im opening my 2011 file the 3d view cannot be viewed and has a message error, but i can view the plan elevations & sections...only the 3d view.....can you help me to solve this error
arfel,
Please start a new thread with your question - don't piggy back it on a different subject.
Then I will delete this post.
5'8" wall will not be cut by cutplane |
Mon, Nov 13, 2017 at 3:49:59 PM
Void Cut Through Integrated Wall Sweep for Downspout |
Tue, Sep 16, 2025 at 7:50:28 AM
How Do I Cut Out Part Of The Wall? |
Wed, Apr 22, 2009 at 5:30:18 PM
only show wall cut |
Wed, Feb 16, 2005 at 9:37:32 AM
Curtain Wall in a Slanted Wall? |
Wed, Aug 8, 2012 at 9:17:56 AM
