23 Users Online (21 Members):
Forums >> General Discussion >> Revit Project Management >> view range
38 Posts No Rating |
I have a split level school that so far I have not been able to get the view cut correct to show both building A and Building B at the same time as I need to show the whole building envelope in my plan. I now have it showing both floor plans however Building B is missing doors and windows that exist in plan. Really don't want to crop two plans and place on sheet that way however only solution I have right now. Any suggestions? I can attach should that help.
Your solution is to use a plan region that allows you to set different VP for an area. Read about PLAN REGIONS in your HELP.
Edited on: Thu, Sep 15, 2011 at 7:23:50 AM
I'm on it! Will let you know how it goes....Thanks.
brilliant-with huge thanks "WWhub"!
BTW, You can turn off the plan region lines in VG - Annotation tab settings.
Now I can't get a room name to show up when all others are showing. It's telling me to check PR settings. I have adjusted but with no luck. Do not know how to find existing room names level too know what is working as they have shown up NP.
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
