Forums >> Revit Building >> Technical Support >> Phasing: problem with new doors in existing wall joint lines
Thu, Sep 15, 2011 at 6:24:47 AM | Phasing: problem with new doors in existing wall joint lines
Mindauxx
Hello,
I am having another problem. This time it is phasing.
When I put a new door in existing wall (so I demolish an opening), I get these wall-door joint lines (marked) in red/dashed manner. I do not want this. I have found out, that these lines belongs to demolished walls as projection lines. I can control them under phasing: DEMOLISHED/PROJECTION LINES. But why is it so? Why can't it belong to EXISTING WALLS/CUT LINES, so I can control them under visibility/graphics overrides and other ways?
Offcourse, I can change them under phasing: DEMOLISHED/PROJECTION LINES, but then other problems arise, like door plan swing lines also change to thick black ones...
Also I cannot use "linework" function, because these marked lines are unselectable. So I am only left with wasting my time and drafting using "detail lines"....
I am using RAC 2011.
Please help and thank you.
Edited on: Thu, Sep 15, 2011 at 6:26:57 AM
Mon, Sep 19, 2011 at 4:32:08 PM | Phasing: problem with new doors in existing wall joint lines
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
You are using the standard doors, supplied with revit. You can of course change or modify these door families, to act like you want. At three posts, my suggestion is don't get too boged down in the finery of the detailing of these. Lots to learn yet.
Edited on: Mon, Sep 19, 2011 at 4:32:40 PM
How do you hide the joint lines between different wall types?
Fri, Nov 16, 2007 at 8:16:34 AM
Infill walls and phasing
Mon, Feb 19, 2018 at 10:03:25 AM
Creating joint lines!!??
Mon, Mar 27, 2006 at 10:59:33 AM
new to existing slab joints
Tue, Mar 26, 2013 at 9:33:42 PM
Infilling element replaced by a later phase insert must be the same type as the
Thu, Jan 31, 2013 at 2:37:52 PM
Page generation time: 1.1168
