Forums >> Revit Structure >> Technical Support >> Mass Material Problems
Wed, Sep 14, 2011 at 5:22:14 AM | Mass Material Problems
Andyb43
Hi,
I am working on a project in 2012 and have placed a mass to represent a part of the building outside of our responsibilities. The mass is mean to be a blue translucent box (see image 1) however the graphics seem to be a bit buggy, sometimes the mass shows as it should but sometimes it just shows transparent (see image 2). I have tried opening this on another computer and the mass consistently shows as it should but then has printing errors (see image 3).
Any ideas?
Mon, Sep 19, 2011 at 4:37:09 PM | Mass Material Problems
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Why are you using a mass? I never use them. Looks like many other in place objects could be used. Masses must always be turned on in the VG, also may react a little funny under different detail level settings.
Mon, Sep 19, 2011 at 4:59:18 PM | Mass Material Problems
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
probably because you've customized a material, and the installation on your second computer is at odds with a material by the exact same name in the library on the local C: drive.   This is default path for the material library, when you installed the software.
I don't like how revit 2012 changed the materials interface.  Not at all.
Reverting a mass to material <by category>
Thu, Jun 14, 2018 at 3:18:10 AM
Different materials on the same mass
Wed, Mar 16, 2011 at 12:03:16 AM
Creating a mass and filling it with a material.
Thu, Apr 23, 2009 at 3:21:11 AM
Radiate material problems [ 1 2 ]
Sun, Mar 23, 2008 at 2:52:03 PM
18
Massing printing problems
Tue, Feb 9, 2010 at 8:11:10 AM
Page generation time: 1.0685
