Forums >> Revit Building >> Technical Support >> revit 2010 packages
Tue, Sep 13, 2011 at 1:30:35 PM | revit 2010 packages
joewallace
i know this may sound like a strange question but does anyone know how big the 7 content packages are in revit 2010. im talking about the packages that download when you install revit first. my friend is installing it but has a serious bandwidth problem so i was wonder how big are they?
thanks for any help in advance
Tue, Sep 13, 2011 at 2:35:17 PM | revit 2010 packages
I think our library is close to 600 meg ...
Wed, Sep 14, 2011 at 4:31:57 AM | revit 2010 packages
joewallace
is there a way to save the library on to a usb say from another location and then install it on the computer seperatly. if this is possible will it install into the correct directories or would that have to be done manually?
thanks
Wed, Sep 14, 2011 at 7:20:41 AM | revit 2010 packages
There is nothing special about the library so you can move it in any way to anywhere you want.  You will just want to set your file pointers in the option settings under the revit R pulldown.
Seperate Core and Shell / TI Packages in CD
Wed, Dec 7, 2011 at 12:03:52 PM
Consultant Coordination b/t 2010 and 2009?
Thu, Sep 10, 2009 at 6:07:11 PM
Interior design with revit
Wed, Jan 6, 2010 at 1:27:05 AM
Drawing Numbers - Schedules.
Tue, Jun 11, 2013 at 7:35:45 PM
Opening a 2010 file in 2009
Thu, Jul 16, 2009 at 8:51:56 AM
Page generation time: 3.9801
