Forums >> Revit Systems >> Technical Support >> Homerun from junction box
Tue, Sep 13, 2011 at 11:34:11 AM | Homerun from junction box
fic1990
So I circuited a junction box to a panel, then I wanted to draw a homerun manually from the box to the panel and tag (lable) it. When I draw it in though it has all the circuits attached to the panel on the tag, where it should only read the panel name and the circuit number of the junction box on the tag instead of all the circuits on the panel. Any reason the tag might be showing every circuit? It is weird that it is doing this because the junction box is ONLY circuited to one thing (the panel).
Thu, Oct 6, 2011 at 8:46:32 AM | Homerun from junction box
osufuzzy
You might try and add another connector to the j-box.  Then you can put the homerun on its own connector and tag it.  Then you should have it labeled by itself.
Mon, May 14, 2012 at 10:08:41 AM | Homerun from junction box
Rodrique
i have tried creating a reccesed wall mounted juntion box but it doesnt quite come out right
any advice that can help me sort this out?
homerun tag
Thu, Jan 21, 2010 at 2:15:46 PM
Homerun arrows on elektrical wiring
Wed, Jul 21, 2010 at 3:40:14 PM
Multi-wire homerun tag out of order
Fri, Dec 9, 2011 at 10:18:57 AM
Circuit Homerun
Tue, May 5, 2009 at 1:40:57 PM
Junction box
Thu, Feb 19, 2009 at 5:41:45 PM
Page generation time: 1.9836
