Forums >> Revit Building >> Technical Support >> Labels in Titleblocks?
Wed, Nov 30, 2005 at 3:18:47 PM | Labels in Titleblocks?
Brainstem
i want to create new labels in my titleblocks and when inserted they just come up with a "?" which is not editable. what's up?
Wed, Nov 30, 2005 at 4:54:05 PM | RE: Labels in Titleblocks?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You need to load your shared parameters. This is done in project parameters and adding new shared parameters to your drawings sheets/project info. Do a search on project parameters, this has been discussed in detail on how to do this. It's best to do them once in your template file, that way they are always loaded in new projects.
Mon, Nov 10, 2008 at 3:11:41 PM | Labels in Titleblocks?
iiDreamTheaterii
Wouldn't it make sense for Revit to automatically load these parameters when you load the template into the project? Autodesk needs to solve this, cuz it's annoying to have to put in individual parameters every time you have a new project. Blah
Mon, Nov 10, 2008 at 3:30:01 PM | Labels in Titleblocks?
tim123
4 Stars: 19 Votes
It would be too complicated to try and include every type of shared parameters in the software as you can create them for almost anything. Its easy to create the ones that you use often and load them into your template.
Titleblock Labels (Custom to each sheet) [ 1 2 ]
Mon, Oct 5, 2015 at 2:46:21 PM
21
Multiline text on Titleblocks
Sun, Oct 5, 2008 at 8:17:13 PM
Multi-line labels on titleblocks
Fri, Jun 12, 2015 at 12:15:15 AM
TitleBlocks
Fri, Dec 8, 2006 at 8:08:02 AM
Title Labels [ 1 2 ]
Sat, Jun 29, 2013 at 12:54:18 PM
15
Page generation time: 1.1582
