Forums >> General Discussion >> Revit Project Management >> revit 2011 occupancy designation
Mon, Sep 12, 2011 at 11:09:46 AM | revit 2011 occupancy designation
locofococo
is there a way to edit/add occupancy designations to a room? the rooms i'm dealing with have preset designations and i can't figure out how to add any.
Mon, Sep 12, 2011 at 11:25:01 AM | revit 2011 occupancy designation
There are no preset occupancy designations in Revit so someone has already added it in your project or template.
You should be able to click on the room and edit the properties to change this.  If you can't then someone may have set up a schedule key based on another parameter.  Come back if you have this problem.
Mon, Sep 12, 2011 at 12:30:04 PM | revit 2011 occupancy designation
locofococo
THIAT DOES SEEM TO BE THE ISSUE. I CAN'T ADD NEW TYPES.
Mon, Sep 12, 2011 at 12:40:47 PM | revit 2011 occupancy designation
Please follow up with an image of your room properties.  Also look in your schedules and see if you have any schedule keys.  We have no way of knowing what you or someone else has added to your project.  So don't yell at us for trying to help.
Area Plan - Occupancy type Revit Architecture 9.0
Mon, May 4, 2009 at 2:48:54 PM
room tag with occupancy info (2019)
Thu, Jan 24, 2019 at 1:34:42 PM
REVIT OCCUPANCY
Fri, Dec 4, 2009 at 9:14:01 AM
Rename Occupancy name
Wed, Apr 3, 2013 at 7:27:13 AM
Occupancy Loads
Thu, Mar 5, 2009 at 8:40:59 AM
Page generation time: 2.1700
