Forums >> Revit Building >> Technical Support >> room areas, room separations
Wed, Nov 30, 2005 at 2:39:50 PM | room areas, room separations
darinemilio
Revit doesn't seem to want to be consistent in how it calculates room areas. Sometimes it grabs walls, sometimes room separations. It will also calculate area differently depending on the orientation of a room separation line. Has anyone everhad this problem before?
Wed, Nov 30, 2005 at 6:13:23 PM | RE: room areas, room separations
krmccurdy
If had that behavior, but it was always something I was doing wrong. If walls aren't joined correctly you will have problems. When I'm having trouble with rooms, I use a room tag that reports square footage. If it squirts out an s.f. value for the room, it is enclosed by some boundaries. By right-clicking the tag you can look at the blue line to figure out what boundaries define the room. If the room tag gives you an error message of "not enclosed" you will have to figure out where you didn't get things joined properly. If you get other error messages, choose the explain error message and revit will help you. Hope this helps. If not, an example of your problem would help.
Mon, Jun 2, 2008 at 1:59:47 AM | room areas, room separations
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Consistancy would be nice.
My issue here is that I am manually placing separation lines to define a room but Revit is dividing that room up even more.  For example I have a fitting room area that has a common corridor which leads into several enclosed fitting rooms  including disabled and returns room.  Once I use the Room function Revit splits this whole area up into individual rooms which is not what I want.  Is there a way around this???? PLEASE
Mon, Jun 2, 2008 at 6:10:16 PM | room areas, room separations
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Bump
Mon, Jun 2, 2008 at 7:49:17 PM | room areas, room separations
mhans
3 Stars: 10 Votes
Use "non-bounding" option for those items. see also Setting, room and area settings for more options.
Motto: "No Post left behind"
Mon, Jun 2, 2008 at 8:19:42 PM | room areas, room separations
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Ripper
Ive had alook at thoses settings, but I think there could be far more settings to make the room calculation far more powerfull.
Room Separations
Thu, Aug 25, 2005 at 2:14:20 PM
Rooms Not Enclosed
Wed, May 27, 2009 at 10:45:36 AM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
mystery room separations
Tue, Jan 30, 2007 at 1:05:51 PM
Room Bounding - Room area changes, then changes back for no reason!
Wed, Apr 28, 2010 at 6:22:40 PM
Page generation time: 1.9387
