Forums >> General Discussion >> Revit Project Management >> Duplicate buildings on same site
Thu, Sep 8, 2011 at 10:43:00 AM | Duplicate buildings on same site
EnjoyRHCP
Hello all,
I am currently doing preliminary designs for a grouping of townhouses.  For now, I am only modeling one building and the site, but eventually there will be 4 identical buildings on the site.  I've been reading that others are saving each building to its own file, and linking them to a site plan which is also on a seperate file.  Is it possible to save each building as a group?  This would surely affect my performance.  I'm open to all strategies!
(Currently using Revit 2011)
Thu, Sep 8, 2011 at 10:50:48 AM | Duplicate buildings on same site
What would a group do for you?  This is a very bad idea and will not do anything for you.
If the buildings are exactly the same, you only need one building file.  The question is, do you really need to combine them into your site model?  If so, then I suggest you model them using worksets and only have the building shell on for the linked site locations.
Thu, Sep 8, 2011 at 11:15:55 AM | Duplicate buildings on same site
EnjoyRHCP
I figured that saving the model as a group wouldn't be the best direction.  Creating building shell workset as we speak.
Thu, Sep 8, 2011 at 12:47:41 PM | Duplicate buildings on same site
rchoutka
1 Stars: 1 Votes
Why would you make a GROUP out of the BUILDINGS ?   A linked in model is already like a "group"
What you should have is a separate SITE PLAN model.
Into this you LINK in your BUILDING model(s) [ one or more ]  and place them as required [ elevation and direction ]
Then any change(s) to the Building Model will be updated in all the models in your SITE model. If one of the buildings needs to be re-designed, SAVEAS a new model ( ie: BLDG A copied as BLDG B ] then re-link that one to replace as required.
Linking buildings to a site
Thu, Sep 16, 2010 at 4:28:48 PM
Multiple buildings on one site
Wed, Feb 4, 2009 at 6:52:04 PM
One site, many buildings
Wed, Feb 11, 2009 at 8:10:45 AM
One Site. Several Buildings
Fri, May 23, 2008 at 6:45:09 AM
level heights for different buildings
Tue, Jan 24, 2006 at 6:39:29 AM
Page generation time: 0.2313
