Forums >> Revit Building >> Technical Support >> Linework Tool nodes and adjustments
Wed, Sep 7, 2011 at 6:27:02 PM | Linework Tool nodes and adjustments
MYoung
MYoung Avatar
Hi,  I can't recall coming across this problem in previous versions, but I probably did and moved on.  When I use LW to hide half of a line of a wall in plan (where is overlaps a curb below that I want to show), I can't always adjust the line.  I selected LW, made the line invisible, but no nodes show up for me to drag the line I want to adjust.  I've tested various views and objects, and have found that sometimes I am able to adjust part of the line and sometimes not (ie I was able to hide half of a door swing, but not the line of a wall).
Thanks - Mike
linework nodes in section
Thu, Oct 16, 2008 at 8:53:07 AM
Surface Nodes. Help.
Mon, May 10, 2010 at 3:55:51 AM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Linework Tool (LW)
Thu, Mar 11, 2010 at 4:34:30 PM
linework tool - showing through?
Thu, Nov 16, 2006 at 4:20:55 PM
Page generation time: 0.5777
