Forums >> Revit Building >> Technical Support >> Sun Tunnel
Wed, Sep 7, 2011 at 12:23:29 PM | Sun Tunnel
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
Anyone ever try to model a parametric sun tunnel family? I'm not sure the best way to go about it. Currently, I started with a generic face based template and changed the category to window. I insert it into the ceiling (which cuts a void) and adjust the shaft height to get it above the roof and then I cut a hole in the roof. The problem is that I can't get sunlight to shine through like in a window. I have the dome on top and the interior lens as transparent material.
I was thinking about maybe making it a light fixture to artificially appear as sunlight coming through. Any advice?
Wed, Sep 7, 2011 at 12:34:36 PM | Sun Tunnel
A couple of thoughts.
Did you turn on daylight portals?
A real "sun tunnel" would have a highly reflective interior.  Does yours?
Still may not work depending on the number of reflections required to get through the tube.
Thu, Sep 8, 2011 at 7:32:33 AM | Sun Tunnel
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
Thanks for the advice WWhub. I turned on daylight portals but that didn't help. I made the shaft a reflective material and that helped a bit but not much. For now, I just made the interior lens 'self-illuminate' to appear as though light is coming through. I'll keep tinkering and post the family if I can get it to work.
Thu, Dec 22, 2011 at 7:04:56 AM | Sun Tunnel
mattilad
hi absolute BIM. I'm new to revit and struggling to make a sunpipe / sun tunnel for myself. I wondered...could you post yours up here for me to use?
thanks
Thu, Dec 22, 2011 at 3:52:52 PM | Sun Tunnel
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I've attached the best I could do. I never was able to get natural light to pass through so the lens material is just set to 'self-illuminate'. I made it face based so you have to place by looking up at your ceiling. Hope these help.
How to construct a freestanding tunnel?
Thu, Nov 24, 2011 at 3:02:46 AM
Create tunnel within toposurface
Mon, Jul 7, 2014 at 8:58:04 AM
I am trying to model Train Tunnel?
Thu, Jul 14, 2011 at 12:19:12 PM
tunnel under a site
Fri, Feb 13, 2009 at 10:01:30 AM
How does BIM combine 4D and 5D planning in bridge and tunnel projects?
Thu, Dec 4, 2025 at 7:24:21 AM
Page generation time: 0.0480
