17 Users Online (15 Members):
Forums >> Community >> Newbies >> how to cut MULTIPLE walls with a void?
6 Posts No Rating |
I just started to read Mastering Autodesk Revit Architecture 2012. There is an excersize where you apply a void component to several walls all at once. However, whatever I try, I can cut only one wall.
The book says - just cut it,
Please, help me. Tell me how to cut multiple walls with a void or I'm goinna go nuts.
Denn15
You are talking about an in-place void or a wall hosted void?
For an in-place void, the void has to be created in such a manner that it will cut all the walls - it can not just be moved. Then before finishing the void family, select all the walls to be cut, one at a time.
6 Posts No Rating |
yes, I'm trying an in place component.
I feel kind of stupid.
once I click to create an in-place component - walls can no longer be selected (I figure, the are outside of the "in-place") then I create a void, the I use the cut but it picks only 1 wall outside of the inplace component.
What do I do wrong?
After you pick the void and the first wall to cut, the void goes away visually - just pick it again from where it should be and pick your next wall.
Before you "CUT" anything, turn ON "Multiple cut", now you can select the void and the walls
6 Posts No Rating |
IT Totaly worked!!! both ways. Of course it is a bit more convenient to start with a void, because I can see it.
Thank you everyone!
shapeing top of walls with void revolve |
Tue, Feb 12, 2013 at 4:01:01 AM
VOID FORM says there is no geometry to cut.... [ 1 2 ] |
Wed, Dec 17, 2008 at 12:52:27 PM
19
Void Won't Cut Extrusion |
Wed, Feb 13, 2013 at 11:04:26 AM
Diagonal End of Wall - Void + Cut Geometry not working |
Fri, Aug 30, 2013 at 3:25:08 AM
Cut a Void out of i.e. 2x12 Roof If your EXPOSED Rafter tails are 6,8 etc. |
Thu, Mar 6, 2008 at 9:16:45 AM
