Forums >> Revit Systems >> Technical Support >> ASHRAE TBL files and pressure loss calculation in Revit MEP 2012
Sun, Sep 4, 2011 at 4:32:06 PM | ASHRAE TBL files and pressure loss calculation in Revit MEP 2012
lhamel
Hi everybody,
If I wanted to create a new coefficient table (TBL file) for use in a project, what software should I use to create the new TBL file ? Another question: is it normal for REVIT gives me a value of 0 for a loss of pressure for a fitting? So, I can not trust to REVIT for the results. An example: By an inspection of a small network of air duct, REVIT gives me static pressure loss as 7 inches. But calculated manually, I get to 0.5 inch. What is, in my opinion makes more sense. What's wrong ? I brought this issue to autodesk from my dealer and I am still waiting for an answer. Meanwhile, I have to do the pressure drop calculations manually. Which is very frustrating.
duct static pressure loss
Mon, Aug 15, 2011 at 2:18:11 PM
Duct pressure loss calculation
Tue, Sep 29, 2015 at 3:32:05 AM
Heat loss calculation formula
Wed, Apr 29, 2009 at 10:09:09 AM
Ashrae tables plug in - how does it works
Wed, Mar 28, 2012 at 12:31:43 PM
Can't make Revit MEP 2013 calculating pipe pressure losses
Tue, Nov 20, 2012 at 7:04:26 AM
Page generation time: 1.4664
