Forums >> Revit Building >> Technical Support >> In place families
Fri, Sep 2, 2011 at 10:32:47 AM | In place families
Westview
2.5 Stars: 2 Votes
Hi everyone
I recently upgraded to 2012. The problem I am having is when I am creating an in place family the screen goes very light and I have a hard time seeing lines and objects. I dont remember this as bieng a problem with previous issues. Is this a general problem or do  need to change some settings?
Thanks Ed
Fri, Sep 2, 2011 at 12:49:33 PM | In place families
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Make sure that in Grpahic Display Options for the view, you don't have a gradiated background turned on.  hard to see gray on gray, but gray on white or gray on black is pretty clear.
Fri, Sep 2, 2011 at 1:18:38 PM | In place families
Westview
2.5 Stars: 2 Votes
Thanks for replying. When I pick the graphic display options in the properties of the section view, I cant see any place to check the  gradiated background. The only view that I have that option is a 3D view.
Fri, Sep 2, 2011 at 2:54:21 PM | In place families
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I have the exact same problem. I know what it is doing, I just don't know how to fix it.
Here is what is happening.
When you enter into the Inplace family editor, it grayscales all model elements slightly, then when you create extrusions, etc. it grayscales the model elements and any other inplace family elements. This causes the model elements to all but disappear on the screen. Black background might show it better but I can't stand the black background so I don't use it.
In 2D views there is no option for background gradiant.
Fri, Sep 2, 2011 at 3:19:28 PM | In place families
Westview
2.5 Stars: 2 Votes
Thanks
I hope it is just a program setting and can be easily adjusted.
Tue, Sep 6, 2011 at 4:48:01 AM | In place families
emgeeo
3.5 Stars: 7 Votes
It's a setting.
Manage -> Additional Setting -> Halftone/Underlay.
Be careful, this is a global setting and will affect your documents if you are using halftone or underlay functionality to control graphic output.
Tue, Sep 6, 2011 at 9:43:21 AM | In place families
Westview
2.5 Stars: 2 Votes
Thanks so much
That solved the problem.
Filter for in-place families
Tue, Jan 22, 2013 at 8:49:24 AM
Materials for in-place families
Wed, Jul 29, 2009 at 7:07:59 PM
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:05 AM
Massing Vs. In-Place Families
Fri, Jul 17, 2009 at 7:23:22 AM
Why In-Place Families?
Sun, Nov 21, 2004 at 5:51:42 PM
Page generation time: 0.7138
