Forums >> Revit Building >> Technical Support >> How to fix the elevation pointer no rotate with object ?
Fri, Sep 2, 2011 at 6:58:11 AM | How to fix the elevation pointer no rotate with object ?
UTG
http://www.temppic.com/img.php?02-09-2011:1314962940_0.40600100.jpg
Hi all,
I try to made elevation annotation in my style . i found a problem when i insert elevation pointer to elevation body (follow guide text in family)  Elevation body rotate with model it ok true but elevation pointer i can't fix to horizon plane .  Beacuse in family catalog of elevation body is check box rotate with model.
How can solve this ?
Thanks,
Yuthana subpaya-agin
Elevation Tag size and elevation pointer
Thu, Feb 28, 2013 at 7:09:40 PM
Elevation Tag Doesn't Work in Rotated Viewport!
Wed, Aug 10, 2016 at 6:16:18 PM
Rotate of family
Wed, Feb 24, 2010 at 1:32:32 AM
Rotating Objects in Elevation/Section
Tue, Jan 27, 2009 at 8:17:15 AM
3d Rotate object
Tue, Nov 18, 2008 at 5:08:34 PM
Page generation time: 0.4704
