Forums >> Revit Systems >> Technical Support >> please help with custom family...
Thu, Sep 1, 2011 at 2:13:11 PM | please help with custom family...
colerothlauf
very new at creating families...but i created a troffer light fixture and have 2x4, 2x2, & 1x4 types...while in the family itself, i can go up and change the type and parameters change the size of the troffer, just as i intend.....when i load it into a project, i can select the size i want and it shows it just fine...however, after i place it and then select it and let's say change it from 2x4 to a 1x4, it doesn't change the size of the troffer, but does change wattage/name/etc.....i am able to manually change the dimension of the troffer myself in properties...but i would like it to change the troffer size itself when i pick a 1x4 as apposed to a 2x4.....within the family, i have tried to check and uncheck the "lock" column, but that seems to have no effect
any suggestions?
Thu, Sep 1, 2011 at 2:19:02 PM | please help with custom family...
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
It seems what has happened it that you adjusted the types in the family after you had loaded it into the project. When you reload a family you have two options. One is to overwrite just the family and the other is to overwrite the family and all parameter values. Try reloading and using the Overwrite family and parameters options. This should update the values in the parameters with the values contained in the family.
Thu, Sep 1, 2011 at 2:33:46 PM | please help with custom family...
colerothlauf
thanks for idea...but i tried what you described and it still wouldn't change dimensions after i placed it.....i've also tried purging it out and reloading it, but no go
would you mind taking a look at it?
Thu, Sep 1, 2011 at 3:03:59 PM | please help with custom family...
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Your dimension paramaters are currently set as Instance parameters. Set them to Type parameters and it will update with each type.
Thu, Sep 1, 2011 at 3:15:45 PM | please help with custom family...
colerothlauf
ahh, thank you very much...prolly a rookie mistake by i'm learning : )
/case closed lol
Rendering problem with Custon Family
Tue, Mar 11, 2008 at 6:49:58 AM
Preblems with custom families
Thu, Sep 17, 2009 at 8:08:26 AM
Custom Precast Family
Fri, Mar 18, 2016 at 2:48:12 PM
Custom Linetype Not Showing When Inside of Another Family?
Mon, Jan 25, 2016 at 9:11:55 AM
Help Rescaling a custom family
Mon, Aug 22, 2011 at 9:59:33 AM
Page generation time: 1.9651
