Forums >> Revit Building >> Technical Support >> Abbreviating Room Tag Names vs. Schedule
Thu, Sep 1, 2011 at 11:03:53 AM | Abbreviating Room Tag Names vs. Schedule
leothelionator
Is there a way to display a room name in abbreviated format on the room tag while simultaneously displaying the full room name on the room finish schedule?  Many times, the name simply does not fit into the room and looks clumsy with the leader option.  Why is that all the smallest rooms get the biggest names!
Examples:
"HOT WATER CLOSET" vs. "H.W."
"JANITOR CLOSET" vs. " JAN"
"ELECTRICAL/MECHANICAL ROOM" vs. "ELECT/MECH"
Thu, Sep 1, 2011 at 12:32:59 PM | Abbreviating Room Tag Names vs. Schedule
The only way to do this is to have an abbreviated room name parameter assigned to rooms and to create a new tag that uses that parameter instead of the Room Name.  .... << And I have done this on some projects.
Thu, Sep 1, 2011 at 1:05:21 PM | Abbreviating Room Tag Names vs. Schedule
leothelionator
Thanks, that's what I was thinking all along.  The main complaint I would have with that method is that I would have to copy all the same exact names twice; one for the schedule and one for the customized room tag since most room names don't need to be abbreviated.
Thu, Sep 1, 2011 at 1:16:56 PM | Abbreviating Room Tag Names vs. Schedule
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Just go ahead and create the tag, but only use when you need an abbreviated room name. This will eliminate the need to do this to all tags.
Edited on: Thu, Sep 1, 2011 at 1:17:53 PM
Thu, Sep 1, 2011 at 2:05:14 PM | Abbreviating Room Tag Names vs. Schedule
As James says, only use the abbrev tag in those rooms.  And only fill in the abbrev. value in the rooms where you need it.  I also have room tags that I call Light & Narrow.  They have a smaller font and a reduced width for small scale plan use.
room names not being picked up in door schedule
Mon, Apr 21, 2008 at 10:26:48 AM
Room names Not showing in Schedule [ 1 2 ]
Tue, Jul 24, 2012 at 7:05:38 AM
20
Schedule will not tracj all room names and numbers [ 1 2 ]
Fri, Jul 30, 2010 at 5:15:35 PM
16
Making a Room Tag that will show a Calculated Value from a Room Schedule.
Tue, Jan 25, 2011 at 5:32:37 PM
Door tag that shows to our from room
Fri, Jun 10, 2016 at 9:22:03 AM
Page generation time: 0.4201
