31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Scheduling Compound Walls
2 Posts No Rating |
Is it possible to schedule quantities of individual materials of which the compound walls are made of?
For instance, some walls are composed of 30 cm thick brick core and 7cm thick thermal insulation, and some others are composed of 12 cm brick core and 1 cm plaster on each side. I'd like to generate the schedule with quantities of brick, insulation and plaster used in those walls.
No. They would need to be constructed as separate elements.
2 Posts No Rating |
Thanks for the quick response Mr. Spot.
Do you know any other method or workaround?
Has anyone tried to extract information on used materials through ODBC export?
Real compound walls |
Sun, Feb 20, 2005 at 8:26:42 PM
non compound wall acting like compound wall |
Mon, Feb 20, 2012 at 2:30:22 PM
Partial Vertical Reveals in Vertically Compound Walls |
Thu, Jul 24, 2008 at 1:04:53 PM
Compound Walls |
Thu, Apr 3, 2008 at 4:55:17 PM
Doors/Windows in Compound Surfaces |
Wed, May 31, 2006 at 10:06:21 AM
