Forums >> Revit Building >> Technical Support >> how to make an two dimentions of horizontal pattern in revit.
Tue, Aug 30, 2011 at 4:44:52 AM | how to make an two dimentions of horizontal pattern in revit.
fairywiner
I want to make a specific pattern like my cad picture.  with seven six hundred millimeter and one three hundred millimeter horizontal line.  The second picture showed my pat file, but when I loaded it into my wall, it only shows three hundred millimeter pattern without the shift between 6 millimeter and 3 millimeter pattern.
沧海月明珠有泪
Tue, Aug 30, 2011 at 9:43:32 AM | how to make an two dimentions of horizontal pattern in revit.
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Here you go. Its not perfect, but it works. Feel free to edit/share
Wed, Aug 31, 2011 at 2:29:28 AM | how to make an two dimentions of horizontal pattern in revit.
fairywiner
I have worked out my script based on your pat, thank you!!!!
Edited on: Wed, Aug 31, 2011 at 2:31:34 AM
沧海月明珠有泪
How do i make an allternating horizontal 4" and 8" .pat file in notepad???
Tue, Sep 6, 2011 at 6:32:54 PM
Floor pattern direction
Mon, Sep 24, 2007 at 2:48:39 PM
area scheluding automating
Sat, Jun 26, 2010 at 6:17:07 AM
Revit 9.1 Detail compontent fill pattern orientation
Tue, Jan 14, 2014 at 4:18:30 PM
vertical plywood
Fri, Nov 25, 2011 at 8:04:30 AM
Page generation time: 1.7299
