Forums >> Revit Building >> Technical Support >> How to create void extrusion running on 2 different planes on furniture???
Sun, Aug 28, 2011 at 7:29:49 PM | How to create void extrusion running on 2 different planes on furniture???
CRB14
I've built a chair and I want it to have 'soft' edges so it doesn't look so sharp when it renders. I've tried to make a void extrusion to run along the edges but ofcourse both the back and the seat of the chair curve in two directions.....I can make a void extrusion along one curved edge but not two...anyone know how I could do this? or a way to build this chair with 'softer' edges??
Thanks
Mon, Aug 29, 2011 at 8:22:33 AM | How to create void extrusion running on 2 different planes on furniture???
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
instead of using extrusions, try using a 'void sweep' then select the edges of the chair as the path
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:44 AM
Make void extrusion permanent
Wed, Feb 9, 2022 at 6:46:57 PM
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
Void Extrusion Constraint
Tue, Apr 11, 2006 at 9:03:58 PM
Page generation time: 0.6406
