Forums >> Revit Building >> Technical Support >> Revit 2009 Naming Conventions for Detail Titles
Fri, Aug 26, 2011 at 11:17:36 AM | Revit 2009 Naming Conventions for Detail Titles
tmassey
tmassey Avatar
I wish to have the same naming convention on detail plans such as Section Detail for all on one sheet. However Revit will not let me name two details the same. Is there a way to override this.
Using Revit Architecture 2012
Fri, Aug 26, 2011 at 11:22:00 AM | Revit 2009 Naming Conventions for Detail Titles
tmassey
tmassey Avatar
nevermind I found out how.
Fri, Aug 26, 2011 at 11:25:41 AM | Revit 2009 Naming Conventions for Detail Titles
Sure it does.....
Under view properties, you will see two settings:
  • View name
  • Title on sheet
If title on sheet is not filled in, Revit will use the view name.  For obvious reasons, every view needs a unique name in the browser and the browser uses the view name.
parameter naming conventions
Thu, Apr 2, 2015 at 8:44:13 PM
Naming Conventions
Tue, Jun 7, 2011 at 5:45:11 AM
Drawing conventions
Mon, Jun 9, 2008 at 11:26:42 AM
Revit 2009 Schedules
Mon, Jul 25, 2011 at 10:22:50 AM
Viewport titles
Tue, May 9, 2006 at 4:39:09 PM
Page generation time: 1.8217
