Forums >> Revit Building >> Technical Support >> Error message 2012
Fri, Aug 26, 2011 at 9:58:35 AM | Error message 2012
Erik
Dabbling with 2012.  I often get en error message and the view closes.
(an error has occured while drawing the content of this window, The window shall be closed)
It happens when I perform simple tasks, like dimensions or moving an object
The file is only small and at the moment simple
Working with a laptop with 4MB ram, probably on the edge of acceptable spec
Any comments to this?
Fri, Aug 26, 2011 at 10:14:28 AM | Error message 2012
You mean 4GB of ram for sure.  You need the 3GB switch set... search for that in the threads here and on autodesk site.
Fri, Aug 26, 2011 at 8:30:18 PM | Error message 2012
Erik
thanks.  Yes, I did mean 4Gb :-)
I am running Windows 7 64bit, so I thought it did not have the 3GB limit
I am now dabbling on my PC which has a 'high' spec and I can not replicae the problem
Good excuse to get a new laptop :-)
ERROR MESSAGE: STAIRS - rises not intersecting boundries?
Tue, Aug 19, 2008 at 9:12:33 AM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:48 PM
MISSING THIRD PARTY UPDATER - 2013 error message
Tue, Aug 6, 2013 at 9:09:34 AM
PLACING ROOMS WITH ERROR MESSAGE ABOUT ADJUSTING LIMITS 2016
Tue, Oct 4, 2016 at 9:09:33 AM
Keynotes Error Message
Mon, Jan 24, 2011 at 9:12:17 AM
Page generation time: 0.6634
