Forums >> Revit Systems >> Technical Support >> Navisworks to Revit
Thu, Aug 25, 2011 at 11:02:42 AM | Navisworks to Revit
nwmanj
Revit City Community,
Can you import Navisworks file into Revit? If not, do I need to purrchase Navisworks to export to Revit? i appreicate any and all help.
Jaime
Thu, Aug 25, 2011 at 11:11:37 AM | Navisworks to Revit
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
nope navis is just a viewer, you dont necessarily need navis to export...http://usa.autodesk.com/adsk/servlet/pc/item?id=13947462&siteID=123112 this is a link to the export utility problem is that once you generate your nwcs. you will need to have navisworks manage to run the collision detection (of course the most expensive one). if you jsut want to view the nwc you should be able to use navisworks freedom which is free.
hth
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Export Issue from revit to navisworks
Thu, Apr 15, 2010 at 9:14:18 AM
Revit 2010 and Navisworks 2010
Mon, Mar 1, 2010 at 8:15:35 AM
Revit and Navisworks
Tue, Nov 27, 2012 at 2:36:00 PM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:15 PM
Casper the Friendly Ghost Add-in NavisWorks 2016
Mon, Apr 25, 2016 at 5:01:17 PM
Page generation time: 4.6528
