24 Users Online (22 Members):
Forums >> Revit Structure >> Technical Support >> day light portals
2 Posts No Rating |
when I render, it says "0 daylight portals". There are windows in the shot, I double checked the materials which are set to clear glass, I have the setting for sun and artificial light checked, but when I go to the render qualities, the options are grayed out so I cannot click the "daylight portals" option. How do I get these options to be not grayed out?
You'll have to choose a "custom" render settings from the dropdown at the top. Using any of the defaults, draft thru best, they are unchecked.
This will add a lot to your render times, and often isn't necessessary, do a compare and contrast if you have time, so you can judge if the results are worth it to you in the future.
Can you limit Daylight Portals? |
Mon, May 17, 2010 at 1:50:07 PM
Daylight Portals |
Tue, Jan 10, 2012 at 9:34:21 AM
daylight portals |
Wed, May 14, 2008 at 12:03:01 AM
Daylight Portals Rendering |
Mon, Jun 24, 2013 at 7:36:12 AM
daylight portals 0 |
Mon, Nov 25, 2013 at 11:59:51 PM
