Forums >> Revit Systems >> Technical Support >> Hide insulation in MEP 2012
Tue, Aug 23, 2011 at 9:14:49 AM | Hide insulation in MEP 2012
Brecht
Hi
I have the new MEP 2012. When I assign my insulation to a pipe, it's impossible to hide it. Revit just hides the pipe, not the insulation. I know I can hide all insulation in visibility/graphic, but that's not what I need. I want to hide certain parts of the Insulation.
I hope there's a solution for my problem.
Grts
Brecht
Wed, Sep 5, 2012 at 3:20:38 AM | Hide insulation in MEP 2012
MariaDTU
4 Stars: 1 Votes
I have the same problem in 2013 :/
Wed, Sep 5, 2012 at 3:36:06 AM | Hide insulation in MEP 2012
Brecht
I did find a solution.
Select the pipe, click on "Edit Insulation". Then you can hide it width "Hide in View" or "Temporary Hide/Isolate".
Wed, Sep 5, 2012 at 3:38:14 AM | Hide insulation in MEP 2012
MariaDTU
4 Stars: 1 Votes
I just found out it is a bug :/ but you can make the lines invisible.
Wed, Sep 5, 2012 at 3:39:14 AM | Hide insulation in MEP 2012
MariaDTU
4 Stars: 1 Votes
Ohu thanks  :D
pipe insulation and VG
Fri, Sep 6, 2013 at 2:08:39 PM
Insulation
Thu, Jan 9, 2014 at 12:43:43 PM
Plumbing insulation
Thu, Feb 20, 2014 at 8:19:48 AM
TRIMMING PIPES - MEP 2012
Fri, Sep 21, 2012 at 9:06:37 AM
insulation line
Fri, Dec 1, 2017 at 9:57:58 AM
Page generation time: 0.1919
