18 Users Online (16 Members):
Forums >> Revit Systems >> Technical Support >> Boxing beams
Hi,
I have a project which has loads of beams which requrie boxing in at high level.
Previously, I have just drawn a wall at either side of the beam (i.e. offset from the level to the beams height) and then drawn a ceiling below - though this process seems extremely time consuming and fiddly.
Is there a better way?
I made an 'architectural beam' family to accomplish this. Just us a column family and modify. Worked great for me.
Sounds like that could be a plan - but how would you cater for the column casing being made of two layers of plasterboard?   as mine are)
I guess you could create an arch column which consists of two extruded boxes one inside the other??
trying to delete elements |
Fri, Jun 12, 2009 at 6:42:23 AM
joining two beams |
Fri, Jul 6, 2007 at 12:03:10 PM
making beams dotted and upstands |
Tue, Jun 3, 2008 at 3:50:24 AM
Beams that are copied are invisible, while beams placed can be seen?? |
Sat, Jan 20, 2007 at 9:53:43 AM
RVT2015 - Insert steel beams over doorway |
Tue, Apr 25, 2017 at 9:06:47 PM
