12 Users Online (10 Members):
Forums >> Revit Systems >> Technical Support >> Control of imported revit link question
I have a structural drawing linked in where I want to turn off their column lines, and use only the architecturals. I can do it manually, but I have a lot of floor plans to do it in. Can I globally somehow turn it off so no view has them on?
This is where you need view templates. Create a template for each view type ....assign it to the views as appropriate.
Learn to use them because they are very valuable.
Actually, I do use them I didnt know the views from revit links were also inluded, I thought only within the model. Thanks.
6 Posts No Rating |
Hi
you can customise it from revit links by going to visibility/graphics overrides,Revit Links then click on By Host View then select Custom then go to Model Categories where it is set to By Host view change it to custom and then trun off all the things you dont need.
Sorry i hope this help i dont know how else to explain it.
Masking an imported link |
Wed, Aug 24, 2011 at 5:59:56 PM
13
imported DWG visibility |
Fri, Apr 13, 2007 at 12:26:22 AM
Issue with Link/Imported Structural Revit File |
Thu, Jul 23, 2009 at 9:58:57 AM
Looking For Easy Way to Control Lineweights When Linking DWG Files |
Fri, Jan 18, 2008 at 3:17:58 PM
column bubble question |
Fri, Aug 26, 2011 at 3:31:25 PM
