10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> AutoCad Lines
1 Posts No Rating |
I have imported a football field from AutoCAD into Revit for a work project. I can see the lines in 3d mode but not when I render the image. What do I have to do to make the lines show up in the rendering? please help
It will not show up in a rendered view. That is because there are no faces to render. You need 3D objects. A site with something like parking striping will render. You can split a topo face to create the field markings but it would be easier as one - in-place family - solid extrusion - 1/4" thick on your site...which is flat.
What about turning your cad file into an image and using it as a material map or decal or some other trick to work as an underlay for your rendering?
Images will render
Edited on: Mon, Aug 22, 2011 at 4:32:00 PM
Quote by: Holtz, Lou
How to get pipe fittings to appear as simple pipe lines? |
Thu, Mar 20, 2014 at 4:40:08 PM
12
Wiggly Lines when importing Topo into Revit |
Tue, Jun 28, 2016 at 9:46:19 AM
AutoCAD and Revit |
Mon, Apr 29, 2013 at 7:23:19 AM
Creating surface topography from Autocad file |
Fri, Feb 25, 2011 at 4:15:11 AM
Importing AutoCAD topo 3D lines |
Wed, May 25, 2005 at 3:33:44 AM
