9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Brick veneer walls have 'unwrapped' at corners
3 Posts No Rating |
While modifying a completed model with brick veneer walls the previously well behaved walls have 'unwrapped' at all external corners - and I can't find why.They still look fine in all 3D views and render as before, but in the floorplan the frame and cavity run to the exterior surface. The unmodified detached garage made from the exact same wall type has remained wrapped as normal.
Any hints on what I've accidentally clicked to make this happen??
John
3 Posts No Rating |
Sorry, forgot to mention - this is on the latest update version of 2012.
3 Posts No Rating |
OOOOPPS - I was mistaking normal corner cleanup with wrapping - all fixed.
Brick veneer stepping at alternate elevations |
Wed, Aug 14, 2013 at 8:28:36 PM
Partial Vertical Reveals in Vertically Compound Walls |
Thu, Jul 24, 2008 at 1:04:53 PM
BRICK VENEER WALL |
Fri, Jul 22, 2005 at 8:55:04 AM
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:46 AM
230 brick wall wont cleanup to 250 brick veneer wall (images attached) RA2008 |
Wed, Sep 3, 2008 at 12:33:09 AM
