Forums >> Revit Building >> Technical Support >> Doors within Doors
Fri, Aug 19, 2011 at 2:02:58 PM | Doors within Doors
Sarah60
Our firm is using Revit to model a renovation, and though some of the consultants are also using Revit, others are still in ACAD.  When we receive plans from the ACAD users, some-- but not all-- of some door types have the Revit doors (4'-0" wide) along with a 3'-0" door centered inside the leaf and matching configuration.  This happens with single doors and with single swinging doors (which we're using to indicate emergency breakout).  It doesn't happen in all of the doors of these two type, just some here or there, and it is consistent in independent consultants' plans.
Looking in the ACAD floor plan we make for them these doors aren't on a frozen layer or turned off.  And if they were nested objects they should show in all of the doors of a given type, size, and orientation.  Likewise, they are not doors on top of doors-- I tried erasing these doors in the Revit model and tried showing hidden objects and erasing the doors.  No doors are left when I do that, hidden or not.
Any thoughts?  Any help or suggestions are appreciated.
Thanks!
Fri, Aug 19, 2011 at 3:10:23 PM | Doors within Doors
Taking you at your word that you have identical types acting differently.
Is there possibly a phase issue where these might end up on different layers?
... or posibly have been over-ridden VG in the exporting view?
I don't think worksets would make a difference but I would still check them.
Anyone have pocket doors or pivot doors?
Tue, Jun 25, 2019 at 12:37:56 PM
doors opened in 3D views
Wed, Sep 27, 2006 at 9:20:29 AM
Doors not appearing in door schedule... Help
Thu, May 30, 2013 at 11:58:43 PM
Storefront Doors in Door Schedule
Wed, Sep 9, 2009 at 4:32:17 PM
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:11 PM
Page generation time: 0.2444
