Forums >> Revit Building >> Technical Support >> wall sweeps
Fri, Aug 19, 2011 at 1:38:59 PM | wall sweeps
locutus359
I am using a sweep as a cap along the parapet.  There are some walls that have an angled top and the sweep doesn't run along the angle, it stays with the reference plane.  Is there a way I can get the sweeps to run on the angle, or is there another method to put on parapet caps?
Fri, Aug 19, 2011 at 2:21:16 PM | wall sweeps
Don't use a wall sweep.  I would do an in-place sweep.
Read some of the similar threads you see below.
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Wall sweeps line weight
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps
Sun, Jul 12, 2009 at 1:54:07 PM
13
Page generation time: 1.8455
