Forums >> General Discussion >> Revit Project Management >> Beam Tags
Fri, Aug 19, 2011 at 6:11:01 AM | Beam Tags
cemcem
Hello,
I want to change the beam tags the way it gives me numbers in the project: Like if I tag a beam it has to tag it B 001, B 002, B 003. So this property shouldn't come from type properties. Any one has a solution?
Thu, Aug 25, 2011 at 7:31:25 AM | Beam Tags
cemcem
I found my own solution: If you buy revit, there is a pack coming along with it. Its called subscription advantage pack. In Revit Extensions there is a add in named Element Positioning. It does what I want.
Beam & Column tags
Tue, Jun 14, 2005 at 4:48:53 AM
Beam System Tags
Wed, Feb 27, 2013 at 12:55:27 AM
Beam tag on roatated beam
Fri, Feb 22, 2019 at 3:21:01 PM
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Page generation time: 1.5699
