Forums >> Community >> Newbies >> Door/Window tag to not display unit symbol?
Thu, Aug 18, 2011 at 12:53:40 PM | Door/Window tag to not display unit symbol?
dsmelcer1234
Is it possible for window and door tags to display the size without the unit size. I want 2'-8" x 6'-8" to display as 2868. When I change the unit formatting to Feet and fractional inches, the unit symbol grays out disallowing me to select "none." When I select decimal feet I can select none but I don't want it to say 3280, as framers around here would think that means 3'-2" x 8'-0" size opening. My current cad software allows me to do this. Thanks for you help.
Thu, Aug 18, 2011 at 2:09:46 PM | Door/Window tag to not display unit symbol?
If you add a type parameter (shared) to your door families that includes this number, you can use it in a tag but you can not get it directly from the size of the door.
Thu, Aug 18, 2011 at 2:52:18 PM | Door/Window tag to not display unit symbol?
dsmelcer1234
Do you think I could use a formula to dynamicaly extract this data and store it in a parameter. I am reserching formula functions to see if this is possible but a nudge in the right direction would help. Basically concatenate(width + height). Can you extract the feet or inches out of a Length?
Thu, Aug 18, 2011 at 3:00:43 PM | Door/Window tag to not display unit symbol?
Revit has no text functions....
Revit does not convert lengths to text ....
You have to add this text data if you want it displayed this way - type or instance variable (shared) in order to be read by the tag....
Thu, Aug 18, 2011 at 3:06:25 PM | Door/Window tag to not display unit symbol?
dsmelcer1234
OK Thanks. I keep hearing how "powerful" revit formulas are but I am beggining to think differently. I keep searching in the help file and google searches like "Complete List of Revit Formula Functions" and all I get is a handful of operators,round, and a few logical statements. Skecthup dynamic components has way more functions than this unless I am missing the complete list.
Thu, Aug 18, 2011 at 3:44:54 PM | Door/Window tag to not display unit symbol?
dsmelcer1234
Ok I figured out how to get it dynamically. I had to think about it for a little bit. Just fyi for any other newbies.
Created 4 shared parameters (integers) in the door/window: widthFeet, widthInch, heightFeet, heightInch.
...for a door 2'-8" x 6'-8"
The formulas
1. widthFeet = rounddown((Width / 0'  1") / 12) ...... Returns 2
2. widthInch = CryingWidth / 0'  1") - (widthFeet * 12)......Returns 8
repeat for height.
Add these parameters to a tag and include all 4 in a label. My only question is can I remove the space in between the parameters? The format button is grayed out for a shared parameter in a tag.
Door / Window Tag
Tue, Mar 4, 2008 at 1:01:44 PM
Need help tagging/scheduling a door with a sidelite
Tue, Jun 8, 2010 at 2:15:22 AM
Door Tag driven by door parameter.
Tue, Jun 28, 2011 at 12:01:00 PM
Craeating Currency Unit Symbol
Thu, Sep 27, 2012 at 2:35:04 AM
DOOR TAG QUESTION
Fri, Mar 1, 2013 at 7:32:19 AM
Page generation time: 0.9613
