22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Best way of creating column casings
Hi,
In our building the steel columns will be cased in 2 layers of plasterboard, which is the same finish as the partition walls.
The engineer has produce a model of the steelwork, I've used rectangular architectural columns which 'warp' the plasterboard wall surface around the column - this works great.
The problem I have is where a column is not against a wall, its in the middle of the room - when I use an Architectural Column its has no surface to attach to, and so does not show two layers of plasterboard.
Whats the best way of casing independant columns?
Thanks.
draw a wall around them, if columns are rectangular, then include nailer, if columns are wide flange then use two different walls one with nailer, one just drywall.
Yea - we though of doing that, I just wondered if there was a 'clever' way of doing this, like the way architectural columns work.
I guess not then.
Thanks for your reply.
Creating Columns |
Tue, Sep 6, 2011 at 2:56:33 PM
Tagging Graphical Column Schedule |
Wed, Nov 24, 2010 at 8:41:14 PM
Column Schedule |
Mon, Apr 21, 2008 at 7:35:29 AM
Column base plate tag units display. |
Mon, Nov 17, 2014 at 2:24:40 PM
creating column based with carvings |
Wed, Oct 5, 2005 at 6:01:29 PM
