21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> TREES
5 Posts No Rating |
HIROSHI ( OR ANYBODY) CAN'T CHANGE SIZE PARAMETERS OF TREES-HEIGHT AND DIAMETER OF SPREAD. ANY IDEAS?
RON FILSON
----------------------------------- Ronald Filson FAIA |
admin
you should be able to change the height and spread of the trees in shaded view by modifying the type properties. However, you'll notice that it doesn't change when you render it. In order to change this you have to change the accurender source. To do this, go to the type properties for the tree you are trying to modify. Under the "Plant Name" category, click the accurender material and a little arrow should appear. When you click on the arrow the plant library should pop-up. right-click the accurender plant/tree of your choice and select "edit". This is where you can change the diameter of the tree (the height automatically updates based on diameter) I hope this is confusing enough. :-)
Hiroshi
2D trees - Elevations |
Wed, Oct 10, 2012 at 4:00:17 AM
Rendering Trees in Revit 2010 |
Wed, Apr 27, 2011 at 2:53:37 PM
Revit 2012 problem rendering RPC trees |
Tue, Sep 6, 2011 at 5:26:07 AM
Rendering Trees |
Mon, Mar 19, 2007 at 7:15:32 PM
Some trees not casting shadows |
Thu, Oct 16, 2014 at 10:55:22 AM
