Forums >> Revit Building >> Technical Support >> Exported .dwg file crashes AutoCAD
Tue, Aug 16, 2011 at 8:04:58 AM | Exported .dwg file crashes AutoCAD
dainaf
5 Stars: 3 Votes
I have exported a sheet view to .dwg(AutoCAD2000) and have been trying to open it in AutoCAD2009.
Every time it crashes and gives me a message "AutoCAD Application has stopped working" with the following details:
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: acad.exe
  Application Version: 23.2.56.0
  Application Timestamp: 47aea35d
  Fault Module Name: StackHash_834c
  Fault Module Version: 6.0.6002.18327
  Fault Module Timestamp: 4cb74dd3
  Exception Code: c0000374
  Exception Offset: 00000000000aca57
  OS Version: 6.0.6002.2.2.0.768.3
  Locale ID: 1033
  Additional Information 1: 834c
  Additional Information 2: 62bfcd41fea33c7176d4cbabcef19dee
  Additional Information 3: 2512
  Additional Information 4: 71d8a03690da1890a17ae4f31a40237f
I've attached the .dwg file if you can take a look.
Has anyone encountered this problem?? I would appreciated any info on this.
Thanks everyone!!!!
Edited on: Wed, Aug 17, 2011 at 3:08:20 PM
Edited on: Wed, Aug 17, 2011 at 3:08:51 PM
Edited on: Wed, Aug 17, 2011 at 3:09:13 PM
Tue, Aug 16, 2011 at 9:39:44 AM | Exported .dwg file crashes AutoCAD
coreed
coreed Avatar
4 Stars: 16 Votes
there is nothing in the file. the problem must be with the xref.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Aug 16, 2011 at 11:00:22 AM | Exported .dwg file crashes AutoCAD
dainaf
5 Stars: 3 Votes
>coreed
Thanks for your post. I just opened it up in a different computer and it opened. It might have been a Window Vista problem.
Exported AutoCAD file is too large
Tue, Jan 18, 2011 at 2:22:06 PM
Sheets exported to DWG
Tue, Jan 15, 2008 at 5:42:15 PM
Some problems with the export from rvt to dwg
Thu, Jan 14, 2010 at 3:10:42 AM
extracting hatch pattern from autocad file
Wed, Sep 21, 2011 at 4:01:20 PM
raster image issue when exporting titleblocks to dwg / autocad
Tue, Sep 9, 2008 at 12:12:42 PM
Page generation time: 0.7904
