Forums >> Revit Building >> Technical Support >> Greyscaling elements at a distance?
Tue, Aug 16, 2011 at 5:59:30 AM | Greyscaling elements at a distance?
leemask
When in elevation views or even sections, is there a clever way to show elevations 'set-back' from the foreground wall in grayscale? It would be good say, if you could set everyone that is a certain distance back to grayscale (or something similar) automatically. Anyone ever done this or have any ideas?
Many thanks (newbie!)
Tue, Aug 16, 2011 at 7:35:22 AM | Greyscaling elements at a distance?
This has been asked for since the beggining of Revit.  If you search the forums you will find many posts on this.  Here is a start: http://www.revitcity.com/forums.php?action=viewthread&thread_id=11267
Tue, Aug 16, 2011 at 7:54:00 AM | Greyscaling elements at a distance?
leemask
Great, thanks for that. I thought there may be one or two threads already re: this, just didnt really know how to word any searches.
Ill stick with the layering of masses for now, I can live with that and seems to give me quite a nice affect of the depth. Still cant figure why Autodesk havent sorted this yet?
Lee
Tue, Aug 16, 2011 at 11:51:05 AM | Greyscaling elements at a distance?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Seems autodesk could do it fairly easily with some additional categories to view depth, to set solid lines, then poched lines.
Tue, Aug 16, 2011 at 7:30:52 PM | Greyscaling elements at a distance?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I don't see why they can't have two tiers of draggable extents to a depth clipping, such as on a section.  One line being a hard limit, one being a grayed point.  Seems sensible, and I imagine pretty easy to code.
graphical cut back distance
Thu, Aug 19, 2010 at 11:14:35 PM
Calculating Distance
Fri, Nov 7, 2008 at 8:35:26 AM
Distance Learning Seminars
Tue, Oct 24, 2006 at 3:36:21 PM
Array Distance Parameter
Thu, Apr 11, 2019 at 8:53:57 AM
spot slope to show 1:distance
Wed, Jan 19, 2011 at 9:19:28 AM
Page generation time: 0.5389
