Forums >> Revit Building >> Technical Support >> Reset curtain wall
Tue, Aug 16, 2011 at 5:55:05 AM | Reset curtain wall
archie456
3 Stars: 1 Votes
Hi,
I have several curved curtain walls meeting in a building - which is a little complex.
As part of setting up the walls, I've been changing the mullion types and deleting a few to see how the joins work.
I've now got the situation whereby the curtain walls are not correct, with some mullions missing, a curtain wall panel doesn't fit the space, and also two situations where there are two mullions on top of each other.
Is there anyway I can 'reset' the layout of the curtain walls, mullions and panels to be as per the type settings? Or do I have to delete them and redraw (which I'm really hoping to avoid).
Cheers.
Tue, Aug 16, 2011 at 7:40:52 AM | Reset curtain wall
If you have a fully automatic CW type and this is the same already, you could switch your existing to a different type, then switch it back to this type.
Be aware that this may not solve your issues.  I prefer to use automatics only for initial placement, then I switch them to fully manual afterwards so that I can modify gid lines, mullions, panel type and be able to adjust panel widths for SF doors.
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:11 AM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall
Sat, Jan 10, 2009 at 10:01:35 AM
Page generation time: 2.8368
