Forums >> Revit Structure >> Technical Support >> i dont know what is this for
Tue, Aug 16, 2011 at 3:45:58 AM | i dont know what is this for
albertiglesia
albertiglesia Avatar
hi,
can somebody tell and explain to me for what is this for? this picture (attached file) was taken from structural column family, i cannot find any use of this
"Pleasure in the job puts perfection in the work"
 - Aristotle
Tue, Aug 16, 2011 at 7:14:27 AM | i dont know what is this for
All families have this setting option.  This is used to control the availability of information from nested families.  Shared means that information will be available in the project.
From the HELP:> "When you use shared families to create a nested family, you can select, tag, and schedule the individual subcomponents in a project. (If subcomponents are not from shared families, Revit Architecture treats an instance of the nested family as a single item for selecting, tagging, and scheduling.)
See also nested family. For more information, see The Families Guide.
Tue, Aug 16, 2011 at 8:10:29 AM | i dont know what is this for
albertiglesia
WWHub,
thank you very much for the reply
i really hate to say this but i still cannot get it, i checked and uncheck the box and it seems theres nothing happen. you said by checking or unchecking the box i control the availability of the information in the nested family. in this case (the picture was taken from the structural column family) the b & h are not shared by default, to make it appear on the schedule you must go the family, edit it and make it shared using modify button on FAMILY TYPE DIALOG BOX, without doing this the b and h cannot be appear into the schedule, the shared thick box cannot control the visibility of the b and h.
do i sound loss? please help me
what nested family anyway? what is the difference of this to other family?
thanks,
please have more patience to me because i know nothing Sad
 - Aristotle
Tue, Aug 16, 2011 at 8:17:06 AM | i dont know what is this for
albertiglesia
because my idiotness is incomparable to anyone here, let me add this to my previous question though i really feel that this question is very elementary that i should already know this yet i still dont know thats why i am asking this
attached is the file image taken from structural column family property box, i don't know what is this for, can somebody tell me patiently and explain it to me what this is for?
please have patience to me
 - Aristotle
Tue, Aug 16, 2011 at 8:18:18 AM | i dont know what is this for
albertiglesia
i cannot attached the image file
anyway the one i am asking is about ALWAYS EXPORT AS GEOMETRY, its also on the structural column family property box, what is this for?
also if you will go to the family type dialog box, you will see the LOCK column cell and there is one tick box on every b and h , what is this for? by default theres a check on each tick box, what will happen if i uncheck the b and h? i cant see any difference if i uncheck this two tick boxes. please explain
Edited on: Tue, Aug 16, 2011 at 8:23:07 AM
Edited on: Tue, Aug 16, 2011 at 8:28:21 AM
 - Aristotle
Tue, Aug 16, 2011 at 8:33:16 AM | i dont know what is this for
Before we go any furthur, let's start by getting you some better tools.  Please download the families guide from here: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13092938&linkID=9243140
In that, you will find a chapter on creating nested families.  See if that helps you understand what nested families are and how they work.
Dont know how to download families
Wed, Jan 31, 2018 at 11:50:15 AM
12
dont have anything under doors, windows, column. etc.
Mon, Dec 26, 2011 at 9:49:10 AM
Masking and filled regions dont cover dimensions and tags??
Wed, Apr 9, 2008 at 11:12:17 AM
Why do some lights turn off but other dont when I render my model?
Sat, Jun 15, 2013 at 5:30:16 PM
sketchup imports dont show edges withing planar facees
Tue, Mar 6, 2018 at 5:59:52 PM
Page generation time: 0.1087
