Forums >> Revit Building >> Technical Support >> Roating furniture in Revit
Mon, Aug 15, 2011 at 4:06:54 PM | Roating furniture in Revit
jawils03
Hi,
I'm new to the Revit community, I just started using Revit over the summer. I am adding in a park bench for my rendering but I am having a hard time trying to figure out how to roate the " park bench" so that it is completely flat on the ground surface. Any suggestions? Tks.
Mon, Aug 15, 2011 at 5:14:17 PM | Roating furniture in Revit
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
A picture would help I think.  When you say flat, do you mean... parallel to the ground plane?  Because the bench should be flat already, unless your active work plane is some sort of skewed reference plane you've made.
Tue, Aug 16, 2011 at 7:40:23 AM | Roating furniture in Revit
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
are you maybe using a face based component which is hosted by a sloped toposurface, isn't this ideal? if you want it flat, try placing a new one but change the Placement option to 'Work Plane' and select a flat workplane in the model.
Fri, Aug 19, 2011 at 12:42:59 AM | itsmyalterego
jawils03
Quoting itsmyalterego from 2011-08-15 17:14:17
Hi!
I attached a jpeg of the file I am working on. As you can see the bench it "upwards", instead of laying flat against the side walk. I am working in the regular views like plan 1 etc. What do you think. I tired moving it, rotating it , but nothing works, it just remains upwards... Thanks....
Fri, Aug 19, 2011 at 12:48:08 AM | AbsoluteBIM
jawils03
Quoting AbsoluteBIM from 2011-08-16 07:40:23
"this is an image from the file I'm working on. As you can see the park bench is upwards and not laying on the concrete sidewalk. I tired to rotate it but it will not flip or moving so that it lies in the correct direction...what do you think? I working in the regular views, ( plan etc )....
Fri, Aug 19, 2011 at 1:13:55 PM | Roating furniture in Revit
As you have been told, If this is a face based family, pick a different host.  Try it in a different project.
Fri, Aug 19, 2011 at 11:35:47 PM | AbsoluteBIM
jawils03
"thank you"..
Sun, Aug 21, 2011 at 11:06:44 AM | Roating furniture in Revit
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
You have to rotate it within the family, just rotate it in an elevation
Furniture Tags & Sketchup Furniture Components
Fri, Dec 4, 2015 at 9:35:33 PM
Difference between Furniture & Furniture Systems
Thu, Jan 4, 2007 at 2:37:47 PM
Cant Tag Furniture. keeps asking to load furniture tag
Sun, Dec 9, 2012 at 6:59:11 PM
Turning off Certain Furniture
Tue, Jun 20, 2006 at 2:09:52 PM
Modern furniture
Mon, Jul 27, 2015 at 10:25:57 PM
Page generation time: 3.4131
